查看: 4167|回复: 1
[SolidWorks] SW2014安装
发表于 2018-1-15 19:40:13 | 显示全部楼层 |阅读模式
1. Install SW2014 SP0.0 using next serials
SolidWorks Serial:
0000 0000 0000 3486 Q5HF FG98
or
0001 0001 0736 0361 JK3Q HDJ3
For other modules USE ONLY THESE SERIALS:
SolidWorks Simulation
9000 0000 0001 8043 TB9T SGD9
SolidWorks Motion
9000 0000 0002 7942 9KW4 9FBC
Flow Simulation
9000 0000 0003 3107 V8F3 PG44
SolidWorks Electrical Schematic (不装)
9000 0000 0000 1616 MDZ8 R8J2
SW Composer
9000 0000 0021 4754 DCB4 HC3J
SW Composer Player Pro
9000 0000 0022 1655 536J H9KH
SW Electrical 2D
2. Run "SW2010-2014.Activator.GUI.SSQ.exe" (as Administrator!). On "General" tab check if all SW2014 products are selected to activation and click "Activate!"
3. Wait for Activator message "All done! Enjoy" and click OK to close Activator
4. Enjoy
To install Workgroup PDM Server:
1. Install IIS full configuration if you plan using Web Portal
2. Install PDM Server from CD
3. If your computer is not connected to Internet, use arbitrary email and SW serial to get a key from PDMWorks keygen
4. If installing Web Portal, leave license string from Workgroup PDM Viewer empty
5. When installation completes, apply a fix inside keygen
6. Reboot your computer
7. Enjoy!
Cracked by Team-SolidSQUAD (SSQ)
发表于 2018-1-29 20:42:23 | 显示全部楼层
GMT+8, 2025-4-21 08:42 , Processed in 0.020390 second(s), 14 queries , Gzip On, Redis On.
