查看: 2624|回复: 0
五金电镀表面处理英语词汇大全
村里打铁的
威望
活力
-5
发表于 2012-12-28 09:37:33 | 显示全部楼层 |阅读模式
五金电镀表面处理英语词汇大全
chromeplate:镀铬Bright chrome plating:镀亮铬white zinc-plating :蓝白锌电镀color-plated zinc:彩锌Electrophoresis:电泳powder coated:烤漆
1.电珍珠铬工艺常用语(Commonly used terminology in process for pearl chrome plating)
硫酸清洗 sulfuric acid clean
超声波除蜡ultrasonic clean
除油degreasing
电解除油 electro clean
酸浸 acid dip
预镀碱铜 alkali copper
焦铜 pyrophosphate copper
酸铜 acid copper
半光叻 semi-bright nickel
氯化叻 nickel chloride
珍珠叻pearl nickel
电铬chromium plated
热水洗 hot water rinsing
烘干 baking
2. 电光铬工艺常用语(Commonly used terminology in process for bright chrome plating)
三氯乙烯清洗 trichloroethylene clean
上挂具 racking
除蜡水洗 ultrasonic clean
电解缸 electro clean
酸水 acid dip
预红铜电镀 copper strike
电红铜 copper
酸水 acid
酸铜 acid copper
氯化叻 nickel chloride
打底叻 primer nickel
镍色 bright nickel
电铬chromium plated
烘干baking
3.静电喷涂工艺常用语(Commonly used terminology in process for electrostatic coating)
合格件上挂 racking
加热脱脂 hot degreasing
水洗 rinsing
酸洗 acid dip
中和 neutralization
表调 surface conditioning
磷化 phosphating
水洗二次 rinsing x2
烘干 baking
检查 inspection
上挂 racking
除尘 dedusting
喷涂 spray painting
固化curing
下挂taking down
包装 packaging
4.静电喷粉工艺常用语(Commonly used terminology in process for electrostatic powder)
合格件上挂 racking
加热脱脂 hot degreasing
水洗 rinsing
中和 neutralization
钝化 passivating
水洗二次 rinsing x2
烘干baking
检查 inspection
上挂 racking
除尘 dedusting
更多详见附件:
GMT+8, 2024-11-23 19:04 , Processed in 0.020116 second(s), 5 queries , Gzip On, Redis On.
