查看: 4060|回复: 0
W11-25*2500卷板机 机械式三辊对称卷板机
发表于 2013-1-10 14:32:09 | 显示全部楼层 |阅读模式
卷制其他材质则事先拿Q235作为相对参数作为标准换算,在允许范围就行。如卷制材质Q345只能卷制厚16mm-18mm宽2500mm的板。或材质Q345卷制厚25mm宽度只能1800mm的板.
该机结构形式为三辊对称式。机械式上辊升降运动由丝杆、丝母、蜗杆传动而获得。两个辊作螺旋运动,通过减速机的输出齿轮与下辊齿轮啮合,为板材行走提供动力。
Mechanical three roller symmetric plate rolling machine
The structure of machine is Three roller symmetry.Mechanical upper roll lifting motion by lead screw,nut,worm drive.The two rollers make screw motion.It can supply power for the plate by the meshing of output gear and lower roller gear of the gear box.
GMT+8, 2026-3-7 05:53 , Processed in 0.055502 second(s), 27 queries .
