- 3323
- 2024-5-7
- 100
- 2011-5-24
- 461
- 1
- 11
- 2912
- 100
螺杆空压机使用说明书(英语版)
Contents
1.0 Products.....................................................2
2.0 Security.....................................................2
3.0 general description..........................................4
4.0 Technical Specifications.....................................6
5.0 installation requirements and start-up inspection before.....7
6.0 operating...................................................10
7.0 Options.....................................................13
8.0 maintenance.................................................14
Intelligent control systems that operate........................21
Screw-type air compressor Manual................................36
1.0 Products
Screw-type air compressor structure of a unique design, a compact, stylish appearance, high efficiency, small energy consumption, low noise characteristics and long life, is a smart environment-friendly products. Is widely applied in metallurgy, machinery, chemicals, and mining, and electric power industries of the ideal gas source equipment. It has:
The third generation of advanced rotor
Concise intake control system
Efficient centrifugal separator oil and gas, gas oil content is extremely small, tube and core of long life
Efficient, Low Noise Suction fan of the full use of export dynamic pressure increased effect of heat transfer (air-cooled)
Automatic water-cooling system for large air compressor to provide more efficient heat transfer capacity (water-cooled)
Packaging materials so that the noise to the minimum level of noise attenuation
Fault diagnosis system, the control panel is easy to operate
Removable door, equipment maintenance, service convenient
Micro-electronic processing so that temperature, pressure and other…………
螺杆空压机使用说明书(英语版).rar(674.9KB)
链接: http://pan.baidu.com/s/1i4BYCs9 密码: twnw |
