查看: 4440|回复: 0
[ABAQUS] ABAQUS错误代码1073741819
发表于 2019-3-15 09:33:56 | 显示全部楼层 |阅读模式
win7,64位操作系统,ABAQUS是6.14-2版本,提交job之前运行了Data Check也没问题,显示“Check Completed”,就是点击Submit后出现以下错误,求大神指导,应该怎么改?
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
GMT+8, 2025-4-21 03:13 , Processed in 0.019536 second(s), 15 queries , Gzip On, Redis On.
