查看: 3070|回复: 2
空气压缩机曲轴零件的机械加工工艺及夹具设计(外文翻译英译汉)
发表于 2013-3-12 20:23:04 | 显示全部楼层 |阅读模式
[b][size=4][color=#4b0082]空气压缩机曲轴零件的机械加工工艺及夹具设计(外文翻译英译汉)[/color][/size][/b]
[color=#ff0000]word档的噢~[/color]
The concept of centrifugal
Centrifugal inertia is the performance of an object, such as umbrellas on the water droplets, when the umbrella slowly rotating, the water droplets will follow the umbrella rotation, because the umbrella and the friction of water droplets to drop as the centripetal force of shiran. However, if the umbrella rotation speed, the friction enough to make water droplets in a circular motion, then drop the sport from the umbrella to the outer edge, like a rope pulling the stones to do with circular motion, if the speed is too fast, the rope will disconnect, stones will be flying out. This is……
离心的概念
  离心其实是物体惯性的表现,比如雨伞上的水滴,当雨伞缓慢转动时,水滴会跟随雨伞转动,这是因为雨伞与水滴的摩擦力做为给水滴的向心力使然。但是如果雨伞转动加快,这个摩擦力不足以使水滴在做圆周运动,那么水滴将脱离雨伞向外缘运动,就象用一根绳子拉着石块做圆周运动,如果速度太快,绳子将会断开,石块将会飞出.这个就是所谓的离心。
  离心泵就是根据这个原理设计的,高速旋转的叶轮叶片带动水转动,将水甩出,从而达到输送的目的。
离心泵有好多种,从使用上可以分为民用与工业用泵;从输送介质上可以分为……
发表于 2013-4-25 15:43:43 | 显示全部楼层
不知道有多少字
发表于 2013-4-25 15:43:46 | 显示全部楼层
不知道有多少字
GMT+8, 2025-4-10 16:43 , Processed in 0.023321 second(s), 18 queries , Gzip On, Redis On.
