3036| 0
[石化通用] 阀门英语词汇 |
阀门英语词汇 阀 clique; clicket; liver; valve 阀板 valve plate 阀瓣 valve clack 瓣式止回阀 flap check valve 阀柄 valve handle 阀槽 valve spool 阀衬 valve bush; valve liner 阀迟关 valve lagging 阀冲程 valve stroke 阀冲水厕所 valve closet 阀弹簧 valve spring 阀弹簧拆卸器 valve spring remover 阀弹簧钢丝 valve spring wire 阀弹簧座环 valve spring collar 阀挡 valve guard 阀导衬套 valve guide bushing 阀导承 strap valve guide; valve guide 阀导承护圈 valve guide retainer 阀导承铰刀 valve guide reamer 阀导承可胀铰刀 valve guide expansion reamer 阀导杆 valve-stem guide 阀导柱 lead of valve 阀道流动阻力 valve passage resistance 阀的操作次数 frequency of valve operation 阀的操作钮 valve-operating stud 阀的装配 setting of valve; valve setting 阀点 valve point 阀点内效率 valve-point internal efficiency 阀点曲线 valve point curve 阀点性能曲线 valve-point performance curve …… 12页word档完整版下载:
购买主题
已有 1 人购买
本主题需向作者支付 3 机械币 才能浏览
手机版|小黑屋|机械村
GMT+8, 2025-4-18 19:25 , Processed in 0.015793 second(s), 6 queries , Gzip On, Redis On.
