- 1253
- 2017-4-8
- 30
- 2011-6-14
- 67
- 0
村里打铁的
- 559
- 威望
- 0
- 242
- 活力
- -2
常用机械零部件中英文对照免费分享,只为攒点人品
天轴 line shaft
可倾瓦块轴承 tilting-pad bearing
成型填料密封 shaped packing seal
曲轴 crank shaft
自润滑轴承 self-lubricating bearing
含油轴承 oil-impregnated bearing
制动功率 braking power
板弹簧 leaf spring
油(气)膜振盪 oil/gas whip
空气弹簧 air spring
花键联接 spline joint
活塞环 piston ring
飞轮 fly wheel
径向滑动轴承 journal bearing
气体轴承 gas bearing
浮环密封 floating ring seal
粉末冶金轴承 powder metallurgy bearing
迷宫密封 labyrinth seal
带式制动器 band brake
推力滑动轴承 thrust bearing
液体动压轴承 hydrodynamic bearing |
