楼主: fiba4069
[ANSYS] ansys各种错误警告的含义和解决办法
 楼主| 发表于 2014-8-29 09:59:26 | 显示全部楼层
NO.0077
*** WARNING *** CP = 1.391 TIME= 17:09:16
Use of the -M switch is no longer recommended for normal ANSYS use.
ANSYS now dynamically allocates memory as needed. Only use the -M
switch if you are certain that you need to do so.
在做谐反应时候遇到的发现是自己自定义ANSYS内存容量使用,在计算时候elements数量过多不能使ANSYS自动调节导致NO.0078
*** ERROR *** CP = 16.859 TIME= 09:29:26
Brick element 91 has an aspect ratio of 1.E+20, which exceeds the error limit of1000000.
不是警告是错误!
用APDL ...
是不是有一个volume的某方向的尺寸要远小于其他volumes的尺寸?比如上下两个volume,上边假设厚度 1mm,而下面厚度可能10E-3或者很小
这时候就会出现这种错误。关于解决方法我建议对一个维度上很小的该部分,用低维单元,比如对三维问题,其他用体单元,而对这个厚度很小的部分定义shell单元设定厚度
NO.0079
*** ERROR *** CP = 89.899 TIME= 17:03:44
The value of UY at node 24320 is 3.673098545E+28. It is greater than
the current.
这个应该是约束不够,Uy方向的位移过大,自查一下约束条件
NO.0080
ring model建立时候遇到的。请指教!Brick element 4731 has an aspect ratio of 1000, which exceeds the
warning limit of 20.
可能是有面网格
NO.0081
tetrahedron element 8120 has a jacobian ratio of 150.5,which exceeds the warning limit of30.Midside nodes,if any,may be poorly positioned.这个问题是说单元的什么比例出了问题啊?要紧么?
雅克比太大,最好改下
NO.0082
*** ERROR *** CP = 160.625 TIME= 08:49:22
The value of UY at node 340 is 4.350676693E+19. It is greater than the
current limit of 1000000. This generally indicates rigid body motion
as a result of an unconstrained model. Verify that your model is
properly constrained.
上面这个ERROR前面有人贴出来过,但是按照给出的方法,还是无法解决问题。
现在可以肯定的是材料参数没问题,约束添加也没问题。我起初以为是网格划分不够细致,于是多次划分,尽量细化。尤其因为出错的节点总是位于一个面的边缘(实体的最上边那个面的边缘)(最下的那个面加的约束),就把这个面特意细化了下,但是这个问题仍然存在。
根据错误的信息y方向上却少约束,存在刚体位移,不知道你怎么确定你的约束没有问题的?你不妨找出node340约束住y方向的位移求解试试看
 楼主| 发表于 2014-8-29 09:59:41 | 显示全部楼层
NO.0083
import .sat file into ansys . The system indicates that ""Line 170 on area 79 is not on the area within a tolerance. This area could have problems in future boolean operations."
I oversee it.
Then I want to make substract operation. It fails and indicates:
"The following entities do not support booleans.Use the SPLOT command to examine bad surfaces/areas Format for SPLOT is PLOT,NA1,NA2,NINC,MESHSIZE
Volume Shell Area Loop Line
1 1 41 1 119
- - - - 120
- - 36 1 114
- - - - 117
- - 38 1 119
- - - - 101
- - 33 1 114
- - - - 90
- - 1 1 3
line170不面area79内,所以如果要用line170来分隔area79就会出错,增大一下布尔操作的容差值(tolerances),BTOL命令
NO.0084
The volume 1 is defined!!
其中同一个程序在运行是:有时候1还会变成20!
我是参数化编程,进行灵敏度分析的时候出现的!
这个我都不知道怎么解决了啊!
可能是由于参数化引起的错误,每一个几何(点、线、面)的编号是与建模及布尔操作命令的顺序有关的,参数化编程时,如果某一个参数的变化会引起所执行命令顺序的变化,就会出现重复定义的情况,不知道是不是这个原因,仅供参考。
NO.0085
错误提示的内容是:The input volumes do not meet the conditions required for the VGLUoperation . No new entities were created . The VOVLAP operation is a possible alternative.
VGLU是将两个或多个体粘到一块,体之间的交集应该是面,帮助里的说法,This operation is only valid if the intersections of the input volumes are areas along the boundaries of those volumes。你粘结glue的体可能有重叠,所以后面提示了一个VOVLAP命令,该命令是将两个或多个体的重叠部分拿出来作为结果
NO.0086
Keypoint 2 belongs to line 4 and cannot be moved应该是关键点2从属于线段4,它不能被删除
NO.0087
在三维计算时,出现这样的错误:Zero volume in element 212630,调试半天,也没弄明白是什么原因?
在这个错误应当是用了相同位置的结点建立了单元,用unmmrg,压缩一下结点应该可以解决问题
 楼主| 发表于 2014-8-29 09:59:51 | 显示全部楼层
NO.0088
Area 2286 is attached to 2 volume(s) and cannot be changed.
怎么出现这个错误?我检查了几遍模型,不知道为什么有这个错误?
意思是面2286从属于2个体,它不能被删除
ansys规定:删除图元,只能从高级往低级删!
NO.0089
节点连成单元出现的,好多次 不知道是啥子原因
Wedge element 1 has an aspect ratio of 29.48,which exceeds the
warning limit of 20?
单元的特征比值为29.48,有于警界限值20,
说明这个单元有奇异
但同样可以计算出结果
如果 这样的单元很少,应该可以不用管它NO.0090
Boolean operation failed.
try adjusting the tolerance value on the BTOL commmand to some fraction of the
minimum keypoint distance.
Model Size (current problem) ...
做aglue时出现提示修改BTOL,后来认真想了,查看了模型,发现两个面并不是相交的,只是共了两个点,所以做aglue时就说要改一下BTOL,因为距离距离超过了BTOL默认的1e-5了
问题应该也是模型并没有真正的出现相交的公共部分。后来把面做更大就通过了,那是由于更大的面可以出现了完整的公共边界了。有点像咱们切瓜果,如果面太小,那会有一部分没有切开
NO.0091
想在已建体(定义为V)中挖四个孔(四个待挖成孔的体孔分别定义为VA,VB,VC,VD),将四个体定义为数组集,即:CMGRP,VV,VA,VB,VC,VD。后用VSBV,V,VV,SEPO,KEEP,命令减去四个孔,但是并没发现k孔的存在,还出现一下警告:请教用命令流如何完成我的目的?
一个体减多个体时,建议还是用GUI操作产生的命令流
因为VSBV,1,ALL这样一条命令本身有问题,ALL就是全部,那1应该在ALL里面,所以会出错。我觉得你遇到的这个错误是否也是出在这里?虽然你用的CM组处理过。
NO.0092
我的默认保存地址怎么也改不了。一保存总是在C盘的C:\Documents and Settings\Administrator里,并且里面的NTUSER.DAT文件怎么也删不掉,想剪切换个文件夹保存,也保存不了,怎么回事?
在launcher里面修改后,最下面有一个"run“按钮,你点"run"运行一次ANSYS,那你修改的东西就会保存了,我以前也没有注意我屏幕显示的这个问题,在launcher里面最下面一行的"run”等几个按钮已经在电脑任务栏下面了,看不见,呵呵。
最后,你删除那个文件做什么?
如果按你说的连剪切都不能做,可能是电脑设置问题,不是ANSYS的问题,除非你没有关ANSYS就想剪切,那当然不行,ANSYS正在用那些文件,你怎么能剪切走呢,复制倒没有问题。
 楼主| 发表于 2014-8-29 10:00:02 | 显示全部楼层
NO.0093
Meshing of volume 5 has been aborted because of a lack of memory. Closed down otherprocesses and/or choose a larger element size, then try the VMESH command again. Minimum additional memory required= ...
好像是说单元过多了。
你也没有说清楚,你是自由网格划分吗?可能精度太高了,产生的单元过多。VMESH划分时,精度不同,单元数量差别太大了,如果是自由网格划分,那么尝试几个SMRT等级看看。还有就是单元形状不同,产生的网格质量也差别很大,我前几天才重新划了一次网格,印象很深。shape,0,3d和shape,1,3d就是划分体时控制单元形状的
NO.0094
Structure elements without mid nodes usually produce much more accurate results in quad or brick shape.
我觉得这是一个建议性的提示,它是说不带中间结点的结构单元可以产生更精确的结果,可以不用理会。
NO.0095
求解时的警告,算出来感觉不对,用solid45单元加在实体边线上面计算时的警告,请问如何解决?谢谢
*** WARNING *** CP = 191.250 TIME= 16:49:39
Selected areas attached to line 154 are not meshed. Surface load PRES
on this line is not transferred. Loads will be transferred to meshed
areas attached to this line.
==提示的意思是没有划分与线154相关的面网格
你先选择线154:lsel,s,,,154,然后选择与154一块的面,asll,再选择相关单元esla,看看有没有选择到单元,如果是0个单元,那是你没有划分相关的面。没有划分单元,那你施加在上面的PRES没有单元可以转上去。
NO.0096
1. Nodes I and J of element 101 ( COMBIN39 ) are not coincident.
2. The variable viewer requires a NUMVAR of 200. The calculator will not
be available. To use the caclulator please export your data to a
file; then choose the 'Clear Time-History Data' button; and then
import your data from the file.
这两个都是警告。。对结果有影响么?
也遇到了你的第一个警告,不知道你可解决了。
我在前处理的时候出现了,没鸟它,然后进行模态分析,又出现了,又没鸟它,再进行时程分析,在时间-历程后处理的时候,发现计算的结果与我预期的比较吻合。虽然如此,但心里总有疙瘩!
首先这个警告是说COMBIN40和14单元的两个节点与单元不匹配。
我用的是11.0版本。做的是层间隔震时程分析。
先建底层柱,然后是二层柱及以上,隔震支座在一层柱顶位置,隔震层的两个节点直接和一层柱顶及二层柱底的关键点共用,这样考虑是隔震层与主体结构两种单元在竖向连接的整体性,然后约束隔震层所有节点的所有转动自由度,最后——allsel,all nummrg,all numcmp,all,之后就出现了如上的警告。
初步分析:14和40号单元在定义时———et,3,combin14,,3,, /et,4,combin40,,,1,,, /et,5,combin40,,,2,,,
关键选项都选择为一维单元,而我又约束了节点三个方向的转动自由度,这样的话,节点与单元便不匹配了,不知道这样闭门造车可能说得过去,有时间我搞个小模型检验一下
 楼主| 发表于 2014-8-29 10:00:13 | 显示全部楼层
NO.0097
There are 21 small equation solver pivot terms.
第一个问题:说明结构刚度矩阵出现小主元。如果矩阵D 的所有主元都是正的,这时结构的切线刚度矩阵正定,结构处于稳定状态;如果矩阵D 的主元有小于0 的,则切线刚度矩阵非正定,结构处于不稳定状态。
如果出现的小主元不多,说明可能是达到某个临界点,以后还可以继续求下去;如果出现的小主元很多,而且越来越多,说明这个结构即将破坏,比如出现大面积的塑性区,形成多个塑性铰等。
当|D |=0时,矩阵D 为奇异矩阵,非线性方程会产生奇异解,奇异解出现于可能产生不定解或非唯一解的分析中,求解方程的主元为负或零会产生这样的奇异解。有些情况下,尽管遇到主元为负或零,仍需继续进行分析(特别是一些非线性分析中)。(since a negative or zero pivot value can occur for a valid analysis.)
下述条件会引起求解过程出现奇异性:(The following conditions may cause singularities in the solution process: )
?约束条件不足
?模型中有非线性单元:如间隙元、滑动元、铰链元、缆束员等。结构的一部分可能已经塌陷或分散了
?材料特性为负:如在瞬态热分析中规定的密度或温度
?连接点无约束,单元排列可能会引起奇异性。例如:两个水平梁单元在连接点的垂直方向存在无约束自由度,在线性分析中,将会忽略加在该连接点的垂直载荷。另外,考虑一个与梁单元或管单元垂直相连的无板面内的旋转刚度的壳单元,在连接点处不存在板面内的旋转刚度。在线性分析中,将会忽略加在该点处的板面内力矩。
?屈曲。当应力刚化效果为负(压缩)时,结构受载后变弱。若结构变弱到刚度减小到零或为负值,就会出现奇异解,且结构已经屈曲。会打印出“主元值为负”的消息。
?零刚度矩阵(在行或列上)。如果刚度的确为零,线性或非线性分析都会忽略所加的载荷。
NO.0098
NO.0003、 Coefficient ratio exceeds 1.0e8 - Check results.
这个大概是跟收敛有关,但是我找不到具体的原因。
好像这个coefficient是指刚度系数,
大多发生在接触定义不当和接触间隙过大倒置,
我作的一个模型,其中有一个弹簧combin39, 当定义两节点不当倒置弹簧不成立时就会出现这个warning,当调节好后,这个warning就会消失
NO.0099
在三维计算时,出现这样的错误:Zero volume in element 212630,调试半天,也没弄明白是什么原因,大家帮帮忙!
模型上的尺寸差别太大,所以划分单元时出现了一些非常小的单元,或者是提示中的0体积单元。我遇到过这个问题,想办法先把体切割一下再划分,不行只能修改前面的建模了。我的当时是由于前面建模时没有注意,出现了一段非常短的线,划分网格时就在那段非常小的线附近出现这样的问题,有时单元设置不好的话甚至不能划分网格。
 楼主| 发表于 2014-8-29 10:00:21 | 显示全部楼层
NO.00100
在计算时遇到Nagative or zero pivot;pivot value=0.0000000e+.000.不知什么原因,且计算直接退出来了!
出现0主元,矩阵没法求解,所以退出了
NO.00101
Memory available for solver = 522.38 MB
Memory required for in-core = 6435.80 MB
Optimal memory required for out-of-core = 758.20 MB
Minim ...
你用的稀疏矩阵求解器,是直接求解器,很耗资源,速度也不是很好,一般适用于10000~500000自由度的问题求解。可以考虑用迭代求解器中的PCG或者JCG求解器。
用命令EQSLV可以换求解器
NO.00102
*** WARNING *** CP = 10.156 TIME= 19:17:20
Cumulative iteration 2 may have been solved using different model or
boundary condition data than currently stored. POST1 results may be
erroneous unless you RESUME from a Jobname.DB file for this substep.
我试过了,你可能当时ansys同时打开了两个db文件,或者你打开的db文件的文件名与你刚刚打开ansys时工作目录下定义的文件名不同
NO.00103
模态分析:主要单元是solid95单元,共11万个单元。
模态分析时,中途中断,跳出错误提示:
*** ERROR *** CP = 1739.797 TIME= 16:31:41
Eigenvalue extraction failed due to a file access error. Possibly
insufficient disk space.
磁盘空间不够!
NO.00104
在用VSBA,ALL,6命令时出现错误:
Topological degeneracy detected for VSBA command Try modifying geometry slightly or loosening the tolerance(BTOL command),If BTOL is relaxed,be sure to change the tolerance back to the default after operation。
相减后产生退化单元,可能是面没有选择好,可以设置boolen 公差(使用BTOL命令),如果公差已经很松弛了,在操作后恢复默认。
发表于 2014-9-22 13:11:52 | 显示全部楼层
受教啦!好东西啊
26
发表于 2014-9-24 14:42:58 | 显示全部楼层
果断收下备用
发表于 2019-12-6 20:35:59 | 显示全部楼层
发表于 2019-12-18 17:15:59 | 显示全部楼层
GMT+8, 2025-4-18 11:19 , Processed in 0.045087 second(s), 3 queries , Gzip On, Redis On.
