查看: 7136|回复: 4
[基础件] 基础件相关德国标准DIN和国际标准、中国国家标准GB中英文对照表
活跃会员不差钱优秀版主马白羊座北京地区勋章
发表于 2014-12-28 08:27:01 | 显示全部楼层 |阅读模式
序号德国标准中文品名英文品名国际标准中国标准
Item DIN-Standard Description in Chinese Description in English ISO-StandardGB-Standard
1 DIN1 圆锥销 taperpins ISO2339 GB117
2 DIN7 圆柱销 parallelpins ISO2338 GB119-86
3 DIN84 开槽圆柱头螺钉 slottedcheese head screws ISO1207 GB65-85
4 DIN85 开槽盘头螺钉 slottedpan head screws ISO1580 GB67-85
5 DIN93 单耳止动垫圈 tabwashers GB854
6 DIN94 开口销 splitcotter pins ISO1234 GB91
7 DIN95 开槽半沉头木螺钉 slottedraised csk head wood screws GB101
8 DIN96 开槽半圆头木螺钉 slottedround head wood screws GB99
9 DIN97 开槽沉头木螺钉 slottedcountersunk head wood screws GB100
10 DIN125-A 平垫 plainwashers ISO7089 GB97.1-85
11 DIN125-B 平垫(带倒角) mediun washers ISO7090 GB97.2-85
12 DIN126 平垫 plainwashers ISO7091
13 DIN127-A 重型弹垫 springlock washers,tang ends GB7244
14 DIN127-B 标准弹垫 springlock washers,square ends GB93-87
15 DIN128-A 鞍形弹垫 singlecoil spring lock washers GB7245-87
16 DIN137-A 弹簧止动垫圈 curvedspring washers
17 DIN137-B 波形弹垫 wavespring washers GB955
18 DIN186 T型方颈螺栓 T-headbolts with square neck GB37-88
19 DIN188 T型双接头螺栓 T-headbolts with double nip
20 DIN258 螺纹圆锥销 taperpins with threaded end ISO8737
21 DIN261 T型头螺栓 T-headbolts
22 DIN315AF 蝶型螺母(美制) wing nuts amercia form
23 DIN315DF 蝶型螺母(德制) wing nuts germany form GB62-88
24 DIN316AF 蝶型螺钉(美制) wing screws amercia form
25 DIN317DF 蝶型螺钉(德制) wing screws germany form
26 DIN319 圆球型盖型螺母 ballknobs
27 DIN404 开槽带孔球面圆柱头螺钉 slottedcapstan screws GB832-88
28 DIN417 开槽长圆柱端紧定螺钉 slottedset srews with full dog point ISO7435 GB75-85
29 DIN427 开槽平端紧定螺钉(半牙) slotted set srews with chamfered endISO2342 GB73-85
30 DIN431 小六角特薄细牙螺母 pipe nutswith thread GB808-88
31 DIN432 外舌止动垫圈 externaltap GB856-88
32 DIN433 小垫圈(用于圆柱头螺钉) washersfor cheese head screws ISO7092 GB848-95
33 DIN434 方斜垫圈(U型) square taper washers for U-sectionGB852-88
34 DIN435 方斜垫圈(I型) square taper washers for I-sectionsGB852-88
35 DIN436 方垫圈 squarewashers
36 DIN438 开槽凹端紧定螺钉 slottedset with cup point ISO7436 GB74-85
37 DIN439 六角薄螺母 hexagonthin nuts ISO4035 GB6172-86
38 DIN439 细牙六角薄螺母 hexagonthin nuts ISO8675 GB6173-86
39 DIN440 木螺钉专用垫圈 roundswashers for wood constructions ISO7094
40 DIN443 密封帽 sealingcaps,push-in type
41 DIN444 活节螺栓B 型 eye bolts form B GB798-88
42 DIN462 内舌止动垫圈 internaltab washers
43 DIN463 双耳止动垫圈 washerswith two taps GB855-88
44 DIN464 滚花高头螺钉 knurledthumb screws with collar GB834-88
45 DIN465 开槽滚花高头螺钉 slottedknurled thumb screws with collar
46 DIN466 滚花高螺母 knurledthumb nuts with collar GB806-88
47 DIN467 滚花薄螺母 knurledthumb thin nuts GB807-88
48 DIN470 锁紧垫圈 sealingwashers
49 DIN471 轴用弹性挡圈 sealingwashers GB894.1-86
50 DIN472 孔用弹性挡圈 retainingrings for bores(internal),circlips GB893.1-86
617
 楼主| 发表于 2014-12-28 08:27:15 | 显示全部楼层
51 DIN478 方头带垫螺栓 squarehead bolts with collar
52 DIN479 方头圆柱底端螺栓 squarehead bolts with half dog point
53 DIN480 方头带垫半圆底端螺栓 squarehead bolts with collar,half dog point and rounded end
54 DIN508 T型槽螺母 T-slotnuts ISO299
55 DIN525 单头螺柱 singleend studs
56 DIN529 地脚螺栓 masonrybolts GB799-88
57 DIN546 带槽圆螺母 slottedround nuts GB817-76
58 DIN547 端面带孔圆螺母 roundnuts with drilled holes in one face GB815-88
59 DIN551 开槽平端紧定螺钉 slottedsit screws with flat point ISO4776 GB73-85
60 DIN553 开槽锥端紧定螺钉 slottedset screws with cone point ISO7434 GB71-85
61 DIN555 六角螺母 hexagonnuts ISO4034
62 DIN557 方螺母-C squarenuts GB39-88
63 DIN558 六角头螺钉 hexagonscrews ISO4018
64 DIN561 六角头圆柱端紧定螺钉 hexagonset screws with full dog point
65 DIN562 薄型方螺母-B squarenuts without bevel(pressed nuts)
66 DIN571 六角头木螺钉 hexagonhead wood screws (coach screws) GB102-86
67 DIN580 吊环螺钉 liftingeye bolts ISO3266 GB825-76
68 DIN582 吊环螺母 liftingeye nuts
69 DIN601 六角头螺栓 hexagonbolts ISO4016
70 DIN603 大半圆头方颈螺栓(马车螺栓) mushroom head square neck bolts (carriagebolts) ISO8677 GB14-88
71 DIN604 沉头带插销马车螺栓 flatcountersunk nib bolts
72 DIN605 沉头长方颈马车螺栓 flatcountersunk long square neck bolts
73 DIN607 半圆头带插销马车螺栓 cup headnib bolts
74 DIN608 沉头短方颈马车螺栓 flatcountersunk short square neck bolts
75 DIN609 六角头精配螺栓(长螺纹) hexagonfitted bolts,long thread
76 DIN610 六角头精配螺栓(短螺纹) hexagonfitted bolts,short thread
77 DIN653 滚花平头螺钉 knurledthumb screws thin type GB835-88
78 DIN660 半圆头铆钉 roundhead rivets ISO1051 GB867-86
79 DIN661 沉头铆钉contersunk head rivets ISO1051 GB869-86
80 DIN662 半沉头铆钉 raisedcontersunk head rivets ISO1051
81 DIN674 大扁头铆钉 mushroomhead rivets ISO1051
82 DIN703 重型侧面带孔圆螺母 adjustingrings,heavy range (shafting collars)
83 DIN705 侧面带孔圆螺母 adjustingrings,light range (shafting collars) GB816-88
84 DIN741 卡头 wire ropeclips
85 DIN787 T型槽螺钉 T-slotscrews ISO299
86 DIN835 双头螺柱(牙长=2D) studs-metal (end=2d) GB900-88
87 DIN906 内六角锥型闭锁螺钉 hexagonsocket pipe plugs,conical thread
88 DIN908 内六角直型闭锁螺钉 hexagonsocket screw plugs,cyl. thread
89 DIN909 外六角锥型闭锁螺钉 hexagonhead pipe plugs,conical thread
90 DIN910 外六角直型闭锁螺钉 hexagonhead screw plugs,cyl.thread
91 DIN911 内六角扳手 socketwrenches ISO2936
92 DIN912 内六角圆柱头螺钉 hexagonsocket cap screws ISO4762 GB70-85
93 DIN913 内六角平端紧定螺钉 hexagonsocket set screws with flat point ISO4026 GB77-85
94 DIN914 内六角尖端紧定螺钉 hexagonsocket set screws with cone point ISO4027 GB78-85
95 DIN915 内六角圆柱端紧定螺钉 hexagonsocket set screws with dog point ISO4028 GB79-85
96 DIN916 内六角凹端紧定螺钉 hexagonsocket set screws with cup point ISO4029 GB80-85
97 DIN917 薄型盲螺母 hexagoncap nuts
98 DIN920 开槽小圆柱头螺钉 slottedshort cheese head screws
99 DIN921 开槽大圆柱头螺钉 slottedlarge cheese head screws GB838-88
100 DIN923 开槽圆柱头轴肩螺钉 slottedpan head screws with shoulder GB830-88
617
 楼主| 发表于 2014-12-28 08:27:24 | 显示全部楼层
101 DIN927 开槽无头轴肩螺钉 slottedshoulder screws
102 DIN928 焊接方螺母 squareweld nuts GB/T13680-92
103 DIN929 焊接六角螺母 hexagonweld nuts GB/T13681-92
104 DIN931 六角头螺栓(半牙) hexagonhead screws ISO4014 GB5782-86
105 DIN933 六角头螺栓(全牙) hexagonhead screws ISO4017 GB5783-86
106 DIN934 六角头螺母(1型) hexagon full nuts ISO4032 GB6170-86
107 DIN934 细牙六角头螺母(1型) hexagon full nuts ISO8673 GB6171-86
108 DIN935 开槽六角螺母 hexagonslotted and castle nuts ISO7035 GB6178-86
109 DIN936 六角头薄螺母 hexagonthin nuts ISO4035 GB6172.1-86
110 DIN937 六角头开槽薄螺母 hexagonthin slotted and castle nuts ISO7038 GB6181-86
111 DIN938 双头螺距(牙长=1D) studs metal (end=1d) GB897-88
112 DIN939 双头螺距(牙长=1.25D) studs metal (end=1.25d) GB898-88
113 DIN940 双头螺距(牙长=1.5D) studs metal (end=1.5d)
114 DIN960 六角头细牙螺栓(半牙) hexagonhead bolts,metric fine pitch thread ISO8765 GB5785-86
115 DIN961 六角头细牙螺栓(全牙) hexagonhead bolts,metric fine pitch thread ISO8676 GB5786-86
116 DIN962 头部穿孔六角头螺栓additional shapes and versions for bolts
117 DIN963 开槽沉头螺钉 slottedcountersund head screws ISO 2009 GB68-85
118 DIN964 开槽半沉头螺钉 slottedraised countersunk oval head screws ISO 2010 GB69-85
119 DIN965 十字槽沉头螺钉 crossrecessed countersunk head screws ISO7046 GB819-85
120 DIN966 十字槽半沉头螺钉 crossrecessed raised countersunk head screws ISO7047 GB820-85
121 DIN970 六角头螺母 hexagonnuts type-1
122 DIN971 六角头螺母 hexagonnuts type-2
123 DIN972 细牙六角头螺母(2型) hexagon nuts with fine thread ISO8674GB6176-86
124 DIN975 牙条(全螺纹) threaded rods(studdings) GB15389-94
125 DIN976 螺纹销 threadedpins(stud bolts)
126 DIN979 六角头开槽薄螺母(2型) hexagon thin slotted and castle nuts
127 DIN980 全金属六角锁紧螺母(1型) prevailling torque type hexagon nuts,allmetall nuts ISO7199 GB6184-86
128 DIN981 圆螺母 locknutsISO2982 GB812-88
129 DIN982 六角头尼龙锁紧螺母prevailling torque type hexagon nuts,heavy type ,with nylon insert ISO7040GB889.1-86
130 DIN985 六角头薄型尼龙锁紧螺母prevailling torque type hexagon nuts,heavy type ,with nylon insert ISO10511GB6172.2-86
131 DIN986 六角盖型尼龙锁紧螺母prevailling torque typedomed capnuts with nylon insert
132 DIN988 配合垫片 shimrings
133 DIN1052 木材连接用垫片 washersfor timber connectors
134 DIN1151 沉头钢钉 roundplain head nails
135 DIN1440 销钉专用垫片A型 plain washers for clevis pins(A型) ISO8738
136 DIN1441 销钉专用垫片 plainwashers for clevis pins
137 DIN1444 带头销钉 clevispins with head ISO2341
138 DIN1471 圆锥型槽销 groovedpins,taper grooved ISO8744 GB/T13829.2
139 DIN1472 圆锥型槽销(半槽) grooved pins,taper grooved half lengthISO8745 GB/T13829.2
140 DIN1473 平行槽销(带倒角) grooved pins,parallel grooved full lengthISO8740
141 DIN1474 前端凹槽槽销 groovedpins,reserve grooved half length ISO8741
142 DIN1475 中部凹槽槽销 groovedpins,centre grooved ISO8742
143 DIN1476 圆头槽销 groovedpins with round head ISO8746 GB/T13829.3
144 DIN1477 沉头槽销 groovedpins with countersunk head ISO8747
145 DIN1479 六角螺母棒turnuckles(centre parts),made out of hexagon bar
146 DIN1480 花篮螺栓turnuckles with eye bolt and hook bolt
147 DIN1481 弹性圆柱销 springpins,heavy type ISO8752 GB879-86
148 DIN1587 组合式盖型螺母 hexagondomed cap nuts GB802-88
149 DIN1804 开槽圆螺母(配合沟头扳手) slottedround nuts for hook spanner
150 DIN1816 圆螺母(带插销孔) roundnuts with set holes
617
 楼主| 发表于 2014-12-28 08:27:35 | 显示全部楼层
151 DIN2093 盘型弹簧垫圈 discsprings
152 DIN3017 喉箍 hoseclamps
153 DIN3404 润滑油嘴(旋扭头)lubricating nipples,button head
154 DIN3567 管夹 shacklesfor conduilts
155 DIN3570 U型螺栓 stirrupbolts(U-bolts)
156 DIN6319 球面垫圈 sphericalwashers,conical seats GB849-88
157 DIN6325 圆柱销 parallelpins ISO8734
158 DIN6330 厚六角螺母 hexagonnuts ,1.5d GB56-88
159 DIN6331 厚六角法兰面螺母 hexagonnuts ,1.5d with collar GB6177-86
160 DIN6334 长六角螺母 hexagonnuts ,3d
161 DIN6797-A 外齿锁紧垫圈 externalteeth lock washers GB862.1-87
162 DIN6797-I 内齿锁紧垫圈 internalteeth lock washers GB861.1-87
163 DIN6798-A 外锯齿锁紧垫圈 externalteeth serrated lock washers GB862.2-87
164 DIN6798-I 内锯齿锁紧垫圈 internalteeth serrated lock washers GB861.2-87
165 DIN6799 开口挡圈 retainingrings for shafts(E-rings),circlips GB896-76
166 DIN6885 平键(A型) parallel keys(form A ) ISO773/2491
167 DIN6888 半圆键 woodruffkeys ISO3912
168 DIN6899 嵌环(支撑环) thimbles
169 DIN6900 机器螺钉和垫圈组合件 screwsand washers assemblies GB9074.1-.17
170 DIN6901 自攻螺钉和垫圈组合件 tappingscrews and washers assemblies GB9074.18-.23
171 DIN6912 薄型带孔内六角圆柱头螺钉 hexagonsocket head cap screws with hole,low head
172 DIN6914 大六角头螺栓 hexagonhead bolts with large head(friction grip bolts)
173 DIN6915 大六角螺母 hexagonnuts with large wideth across flat(friction grip nuts)
174 DIN6916 大垫圈 roundwashers for friction grip bolts
175 DIN6917 楔型方垫圈 spuaretaper washers for friction grip bolts on T-sections
176 DIN6923 六角法兰面螺母 hexagonflange nuts ISO4161 GB6177-86
177 DIN6925 全金属六角锁紧螺母(2型) prevailing torque type hexagon nuts,allmetallic nuts ISO7042 GB6185.1-2000
178 DIN7337 开口型抽芯铆钉(沉头、扁圆头) blindrivets GB12617/12618
179 DIN7338 扁平头半空心/全空心铆钉 rivets for brake and clutch liningGB875/975-86
180 DIN7343 螺旋夹紧销 spiralpins ISO8750
181 DIN7346 轻型弹性圆柱销 springpins,light type ISO13337
182 DIN7349 重型弹性圆柱销用垫圈 washersfor bolts with heavy type spring pinss
183 DIN7500 ISO公制螺纹螺钉(多种头型) threadforming screws for ISO-metricthread
184 DIN7504 自攻自钻螺钉(多种头型) self-drilling tapping screws
185 DIN7513 开槽切削螺纹螺钉(多种头型) thread cutting screws
186 DIN7516 十字槽切削螺纹螺钉(多种头型) thread cutting screws cross recess
187 DIN7965 T型四爪螺母 tee nutswith pronge
188 DIN7968 钢结构用六角头螺栓连接副 hexagonhead fitted bolts for steel structures GB1228/1229/1230
189 DIN7971 开槽盘头自攻螺钉 pan headtapping screws with slot ISO1481 GB5282-85
190 DIN7972 开槽沉头自攻螺钉countersunk flat head tapping screws with slot ISO1482 GB5283-85
191 DIN7973 开槽半沉头自攻螺钉 raisedcountersunk oval head tapping screws with slot ISO1483 GB5284-85
192 DIN7976 六角头自攻螺钉 hexagontapping screws ISO1479 GB5285-85
193 DIN7980 圆柱头螺钉用弹簧垫圈 springlock washers for screws with cylindrical heads ISO8738
194 DIN7981 十字槽盘头自攻螺钉 pan headtapping screws with cross recessed ISO 7049 GB845-85
195 DIN7982 十字槽沉头自攻螺钉countersunk flat head tapping screws with cross recessed ISO7050 GB846-85
196 DIN7983 十字槽半沉头自攻螺钉 raisedcountersunk oval head tapping screws with cross recessed ISO7051 GB847-86
197 DIN7984 薄型内六角圆柱头螺钉 hexagonsocket head cap screws with,reducedhead
198 DIN7985 十字槽盘头螺钉 pan headscrews with cross recessed ISO7045 GB818-85
199 DIN7989 钢结构用垫圈 washersfor steel structures GB1230-84
200 DIN7990 钢结构用六角头螺栓 hexagonhead bolts for steel structures GB1229-84
617
 楼主| 发表于 2014-12-28 08:27:42 | 显示全部楼层
201 DIN7991 内六角沉头螺钉 hexagonsocket countersunk head screws ISO10642
202 DIN7993 轴用钢丝挡圈 roundwiresnap rings for shafts GB895.2-86
203 DIN7995 十字槽半沉头木螺钉 crossrecessed raised countersunk head wood screws GB952-86
204 DIN7996 十字槽圆头木螺钉 crossrecessed round head wood screws GB950-86
205 DIN7997 十字槽沉头木螺钉 crossrecessed countersunk head wood screws GB951-86
206 DIN8140 螺纹护套(普通\自锁等) ciol inserts,coarse,fine thread,silflocking
207 DIN9021 大外径垫圈washers,outside diameter appro.3d ISO7093 GB96-85
208 DIN11024 弹簧卡子 springcotter for a bolt
209 DIN13257 平板螺栓 beltingbolts (elevator bolts)
210 DIN18182 干壁钉(墙板钉) dry wallscrews
211 DIN28129 环型螺母 liftingnuts(eye nuts) GB63-88
212 DIN70952 圆螺母用止退垫圈 tabwashers for slotted round nuts GB858-88
GMT+8, 2026-2-28 09:17 , Processed in 0.058508 second(s), 24 queries , Gzip On.
