查看: 3646|回复: 2
机械类外文文献翻译(认识曲柄摇臂机构设计的最优传动方法)
发表于 2015-12-24 16:46:31 | 显示全部楼层 |阅读模式
中英文对照,word格式~
Abstract: A novel method of realizing the optimal transmission of the crank-and-rocker mechanism is presented. The optimal combination design is made by finding the related optimal transmission parameters. The diagram of the optimal transmission is drawn. In the diagram, the relation among minimum transmission angle, the coefficient of travel speed variation, the oscillating angle of the rocker and the length of the bars is shown, concisely, conveniently and directly. The method possesses the main characteristic. That it is to achieve the optimal transmission parameters under the transmission angle by directly choosing in the diagram, according to the given requirements. The characteristics of the mechanical transmission can be improved to gain the optimal transmission effect by the method. Especially, the method is simple and convenient in practical use.
Keywords:Crank-and-rocker mechanism, Optimal transmission angle, Coefficient of travel speed variation
摘要:一种曲柄摇臂机构设计的最优传动的方法被提出。这种优化组合设计被用来找出最优的传递参数。得出最优传递图。在图中,在极小的传动角度之间, 滑移速度变化系数,摇臂的摆动角度和杆的长度被直观地显示。 这是这种方法拥有的主要特征。根据指定的要求,它将传动角度之下的最优传动参数直接地表达在图上。通过这种方法,机械传动的特性能用以获取最优传动效果。特别是, 这种方法是简单和实用的。
关键字:曲柄摇臂机构   最优传动角度   滑移速度变化系数
购买主题 已有 3 人购买  本主题需向作者支付 1 机械币 才能浏览
最佳新人不差钱
发表于 2017-4-2 23:15:16 | 显示全部楼层
能给个外文的pdf文件嘛?
发表于 2017-4-12 11:11:42 | 显示全部楼层
可以自己放Word文档后,转成pdf格式的。
GMT+8, 2025-4-20 02:34 , Processed in 0.039393 second(s), 5 queries , Gzip On, Redis On.
