查看: 12086|回复: 11
[机械综合] 客户参观工厂英语汇总(高频词+常用句+对话)
发表于 2015-12-25 11:28:40 | 显示全部楼层 |阅读模式
商务英语口语-工厂参观
一、5个有关工厂单词
二、参观工厂10句句子
三、参观工厂对话
一、5个有关工厂单词
  1.Efficiency 效率
  A: What is the efficiency of this product line?
  B: It's about 85%.
  A:这个生产线的效率是多少?
  B:差不多85%。
  2.Labor costs 人工成本
  A: Why do we have such high labor costs?
  B: Our labor workers were from the state owned enterprise.
  A:我们的人工成本怎么这么高啊?
  B:我们的工人是从国企来的。
  3.Lean manufacturing 精益制造
  A: Why do we need lean manufacturing?
  B: Very simple, to cut the costs and increase the efficiency.
  A:我们为什么需要精益制造啊?
  B:很简单,为了节约成本,提高效率。
  4.Power consumption  能源消耗
  A: What is the power consumption for your plant?
  B: Ten thousand KWH each day.
  A:你们工厂的能源消耗怎么样?
  B:每天一万千瓦小时。
  5.PPM 百万分之一件
  A: What is your PPM?
  B: Our PPM is 25.
  A: That's great.
  A:你们的PPM是多少?
  B:我们的PPM是25。
  A:很好。
  Note:PPM means part per million, usually a measure of quality.
  注:PPM是百万分之一件的缩写,通常是质量的一种指标。
 楼主| 发表于 2015-12-25 11:28:54 | 显示全部楼层
二、参观工厂10句句子
Visiting A Factory 参观工厂
1. We look forward to our tour of your plant.
我们盼着参观你们工厂。
2. If it is not too much trouble, we would like to talk to some of the technicians.
如果不是太麻烦的话,我们想与一些技术员谈一谈。
3. We learned a lot about your facilities and the process of wine making.
关于你们的酿酒设备和酿酒过程,我们了解了不少情况。
4. We’re interested in learning about your food-making and pack- aging process.
我们想向你们学习食品加工和包装过程。
5. It was very kind of you to give me a tour of the plant.
谢谢你陪同我参观工厂。
6. You will surely know the products better after the visit.
参观工厂参观后你对我们的产品肯定会更了解。
7. Let me give you this list of departments first.
我先给你这份各个部门的清单。
8. Next to each department is its location and the name of the manager.
在每个部门的旁边都标有其具体位置和经理的姓名。
9. Please let us know when you will be free so that we can arrange the tour for you.
请告诉我们你们什么时候有空,我们好作安排。
10. Does the plant work with everything from the raw material to the finished product?
从原料到成品都是工厂自己生产吗?
 楼主| 发表于 2015-12-25 11:29:04 | 显示全部楼层
三、参观工厂对话
商务英语:参观工厂
谈"生意"才是目的,"说英语"只不过是一种手段。下面就教教大家如何用简单英语邀请和陪同客人参观工厂。
A: Would you like to look around our factory some time? 什么时候来看看我们的工厂吧?
B: That's a good idea. 好啊。
A: I can set up a tour next week. 我可以安排在下个礼拜参观。
B: Just let me know which day. 决定好哪一天就告诉我。
A: Thanks for coming today. 谢谢您今天的光临。
B: I've been looking forward to this. 好久以前就想来看看你们的工厂了。
A: You'll have to wear this hard hat for the tour. 参观时必需戴上这安全帽。
B: This one seems a little small for me. 这顶我戴好像小了一点。
A: Here, try this one. 喏,试试这一顶。
B: That's better. 好多了。
A: We can start at any time you're ready. 只要你准备好了,我们随时可以开始。
B: I'm all set. 我都准备好了。
A: The tour will take about an hour and a half. We can start over here.这次参观大概需要一个半小时。我们可以从这里开始。
B: I'll just follow you. 我跟着你就是。
A: Please stop me if you have any questions. 有任何问题,请随时叫我停下来。
B: I will. 好的。
A: Watch your head as you go through the door there. 经过那儿的门时,小心别撞倒头。
B: Thank you.谢谢。
A: That's the end of the tour. 参观就此结束了。
B: It was very informative. 真是获益良多。
A: Just let me know if you want to bring anyone else. 如果你要带别人来,请随时通知我。
B: I'd like to have my boss go through the plant some day. 我真想叫我老板哪天也过来看看。
工厂参观二
.Inspection gages and fixtures 检测量具和夹具
  A: Who is going to design the inspection gages and fixtures?
  B: It will be the Stone Company.
  A:谁来设计检测量具和夹具?
  B:将会是斯通公司。
  2.Shift 轮班
  A: How many shifts do you have?
  B: Three shifts a day.
  A:你们是几班倒啊?
  B:每天轮三次班。
  3.Production line 生产线
  A: Who is in charge of the production line?
  B: We have a group leader for each production line.
  A:谁来负责生产线?
  B:我们每个生产线都有一个组长负责。
  4.Testing area 检测区
 楼主| 发表于 2015-12-25 11:29:14 | 显示全部楼层
A: Is this the Testing Area of the plant?
  B: You are right. We do part of the quality testing here.
  A:这是工厂的检测区吗?
  B:是的,有一部分质量检测是在这里做的。
  5.Working conditions 工作条件
  A: Are they satisfied with the working conditions?
  B: Some are, and some aren't.
  A:他们对工作条件满意吗?
  B:有的人满意,有的人不满意。
制造工程二
1.Computer-Aided Manufacturing(CAM) 计算机辅助制造
  A: Is CAM used in China?
  B: Yes,it has been uesd in China for almost twenty years.
  A:在中国有使用CAM的吗?
  B:有啊,在中国使用已经将近20年了。
  2.Hot working 热加工
  A: What are the hot working processes?
  B: Hot forging, rolling, extrusion, etc.
  A:热加工工艺有哪些?
  B:热锻、滚轧、热压等等。
  3.Spot weld 点焊
  A: Can you spot weld a tube to a sheet metal?
  B: Yes, you can, with a special shaped electrode.
  A:你能把一个钢管点焊到钢板上吗?
  B:可以,用一种特殊形状的电极。
  4.Turning 车削
  A: Do we do any turning in our plant?
  B: No. We are a chipless machining.
  A:我们工厂有车削加工吗?
  B:没有,我们是无屑加工。
  5.Compression molding 压塑成型
  A: What is compression molding?
  B: You take a plastic or composite sheet, heat it up, and press it into a mold to make a part.
  A:压塑成型是什么?
  B:把一块塑料或复合材料板材加热,压进模具来制作零件的方法转自学易
大家都知道how many和how much是用来提问多少,的意思,那么how many和how much有什么区别吗?
  1、所修饰词的不同
  how many用来修饰可数名词的复数,它的句式是:How many+复数名词+一般疑问句+
  how much用来修饰不可数名词,表示数量,也可单独使用。   2、how many的用法
  (1)对there be句型中主语的数量如:some, five, only one等提问时,如果主语是可数名词,不管主语是单数还是复数一般都用复数形式提问,因为问话人不知道具体的数量是多少,而且many只能接可数名词复数形式,所以be一定要用are.即用How many+可数名词复数+are there+地点/时间状语 的句型结构.例如:
    1)There is a book on the desk. (用how many改为特殊疑问句)
       How many books are there on the desk
    2)There are seven days in a week. (对划线部分进行提问)
         How many days are there in a week
  (2)记忆口诀
  how many在句首,名词复数跟着走,一般问句紧相随,其它成分不要丢.
  3、how much 的用法
  (1)用来询问事物的数量,后接不可数名词。例如:
  How much milk is there in the glass 玻璃杯里有多少牛奶?
  (2)用来询问事物的重量。例如:
    -How much does the pig weigh 这头猪多重?
  -Eighty kilos.八十公斤。
  (3)how much 意为“多少钱”时,可单独使用,也可构成词组how much money,但英语中常省略money,用来询问某物的价钱、价格。
  (注意:how much询问价格时,它的回答若是中国的货币单位应采用汉语拼音yuan,fen来表示,几角常采用几十分来表示,字母用小写,且不用复数。例如:
-How much is the eraser 这块橡皮擦多少钱?-Ninety two fen.九角二分。)
(4)用来询问数字计算的结果,相当于what。例如:
  -How much is three plus one 三加一等于多少?
  -It''''s four.等于四。
发表于 2016-1-14 15:52:18 | 显示全部楼层
发表于 2017-3-9 15:14:27 | 显示全部楼层
很好,如果可以能不能发一些关于在与外国客户交谈时用到的机械英语,谢谢
发表于 2017-3-9 16:25:34 | 显示全部楼层
很好的,支持一下
发表于 2019-1-26 11:19:17 | 显示全部楼层
感觉自己英语还是得多加练习啊
最佳新人
发表于 2019-4-1 14:13:33 | 显示全部楼层
发表于 2019-11-26 16:50:52 | 显示全部楼层
GMT+8, 2025-4-4 04:36 , Processed in 0.027993 second(s), 16 queries , Gzip On, Redis On.
