简称 | 树脂化学名 | 英文名称 |
ABS | 丙烯腈-丁二烯-苯乙烯共聚物 | acrylonltrile-butadiene-styrenecopolymer |
A/S | 丙烯腈-苯乙烯共聚物 | acrylonltrile-styrene-copolymer |
A/S/A | 丙烯腈-苯乙烯-丙烯酸酯共聚物 | acrylonitrile-styrene-acrylate copolymer |
A/MMA | 丙 烯腈-甲基丙烯酸甲酯共聚物 | acrylonitrile-methyl meth acrylat copolymer |
CA | 乙酸纤维素 | cellulose acetate |
CAB | 乙酸-丁酸纤维素 | cellulose acetate butyrate |
CAP | 乙酸-丙酸纤维素 | cellulose acetate propionate |
CF | 甲酚-甲醛树脂 | cresol-formaleehyde resin |
CMC | 甲羧基纤维素 | carboxymethyl cellulose |
CN | 硝酸纤维素 | cellulose nitrate |
CP | 丙酸纤维素 | cellulose propionate |
CS | 酪素塑料 | casein plastics |
CTA | 三乙酸纤维素 | cellulose triacetate |
EC | 乙基纤维素 | ethyl cellulose |
EP | 环氧树酯 | epoxide resin |
E/P | 乙烯-丙烯共聚物 | ethylene-propylene copolymer |
E/P/D | 乙烯-丙烯-二烯三元共聚物 | ethylene-propylene dlene terpolymer |
E/TFE | 乙烯-四氟乙烯共聚物 | ethylene-tetrafluoroethylene copolymer |
E/VAC | 乙烯-乙酸乙烯酯共聚物 | ethylene-vinylacetate copolymer |
E/VAL | 乙烯-乙烯醇共聚物 | ethylene-vinylalcohol copolymer |
PEP | 四氟乙烯-六氟丙烯共聚物 | perfluorinated ethylene-propylene copolymer |
GPS | 普通聚苯乙烯 | general polystyrene |
GRP | 玻璃纤维增强塑料 | glass fibre reinforced plastics |
HDPE | 高密度聚乙烯 | high density polyethylene |
HIPS | 高冲击强度聚苯乙烯 | highimpact polystyrene |
LDPE | 低密度聚乙烯 | low density polyethylene |
MC | 甲基纤维素 | methyl cellulose |
MDPE | 中密度聚乙烯 | middle density polyethylene |
MF | 三聚氰胺-甲醛树脂 | melamine-formaldehyde resin |
MPF | 三聚氰胺-酚醛树脂 | melamine-phenol-formaldehyde resin |
PA | 聚酰胺 | polyamide |
PAA | 聚丙烯酸 | poly(acrylic acid0 |
PAN | 聚丙烯腈 | polyacrylonitrile |
PB | 聚丁烯-1 | polybutene-1 |
PBTP | 聚对苯二甲酸丁二醇酯 | poly(butylene terephthalate) |
PC | 聚碳醇酯 | polycarbonate |
PCTFE | 聚三氟氯乙烯 | polychlorotrifluoroethylene |
PDAP | 聚邻苯二甲酸二烯丙酯 | poly(diallyl)phthalate) |
PDAIP | 聚间苯二甲酸二烯丙酯 | poly(diallyl isophthatate) |
PE | 聚乙烯 | polyethylene |
PEC | 氯化聚乙烯 | chlorinated polyethylene |
PEOX | 聚氧化乙烯:聚环氧乙烷 | poly(ethylene oxide0 |
PETP | 聚对苯二甲酸乙二醇酯 | poly(ethylene terephthalate) |
PF | 酚醛树脂 | thenol-formaldehyde resin |
PI | 聚酰亚胺 | polyimide |
PMCA | 聚a-氯代丙烯酸甲酯 | poly(methyl-a-chloroacrylate0 |
PMI | 聚甲基丙烯酰亚胺 | polymethacrylimide |
PMMA | 聚甲基丙烯酸甲酯 | polym(ethyl meethacrylate) |
POM | 聚甲醛 | poly formaldehyde(polyoxy methy lene) |
PP | 聚丙烯 | polypropylene |
PPC | 氯化聚丙烯 | chlorinated polypropylene |
PPO | 聚苯醚 | poly(phenylene oxide) |
PPOX | 聚氧化丙烯 | poly(propylene oxide) |
PPS | 聚苯硫醚 | poly(phenylene sulfide0 |
PPSU | 聚苯砜 | poly(phenylene sulfide0 |
PS | 聚苯乙烯 | polystyrene |
PSU | 聚砜 | polysulfone |
PTFE | 聚四氟乙烯 | polytetrafluoroetyylene |
PUR | 聚胺酯 | polyurethane |
PVAC | 聚乙酸乙烯酯 | poly(vinyl acetate) |
PVAL | 聚乙烯醇 | poly(vinyl alcohol) |
PVB | 聚乙烯醇缩丁醛 | poly(vinyl butyral) |
PVC | 聚氯乙烯 | poly(vinyl chloride) |
PVCA | 氯乙烯-乙酸乙烯酯共聚物 | poly(vinyl chloride-acetate) |
PVCC | 氯化聚氯乙烯 | chlorinated(poly viny chloride) |
PVDC | 聚偏氯乙烯 | poly(vinylidene chloride) |
PVDF | 聚偏氟乙烯 | poly(vinylidene finoride) |
PVF | 聚氟乙烯 | poly(vinyl fluoride) |
PVFM | 聚乙烯醇缩甲醛 | poly(vinyl formal) |
PVK | 聚乙烯基咔唑 | poly(vinyl carbazole) |
PVP | 聚乙烯基吡咯烷酮 | poly(vinyl pyrrolidone) |
RP | 增强塑料 | reinforced plastics |
RF | 间苯二酚-甲醛树酯 | resoreinol-formaldehyde vesin |
S/AN | 苯乙烯-丙烯腈共聚物 | styrene-acrylonitrile cipolymer |
SI | 聚硅氧烷 | silicone |
S/MS | 苯乙烯-a-甲基苯乙烯共聚物 | styrene-a-methylstyrene copolymer |
UF | 脲醛树酯 | urea-formaldehyde resin |
UHMWPE | 超高分子量聚乙烯 | ultra-high molecular weight polyethglene |
UP | 不饱和聚酯 | unsaturated polyester |
VC/E | 氯乙烯-乙烯共聚物 | vinylchloride-ethylene copolymer |
VC/E/MA | 氯乙烯-乙烯-丙烯酸甲酯共聚物 | vinylchloride-ethylene-methylacrytate copolymer |
VC/E/VAC | 氯乙烯-乙烯-乙酸乙烯酯共聚物 | vinylchloride-ethylene-vinylacetate copolymer |
VC/MA | 氯乙烯-丙烯酸甲酯共聚物 | vinylchloride-methylacrylatecopclymer |
VC/MMA | 氯乙烯-甲基丙烯酸甲酯共聚物 | vinylchloride-methylmethylacrylate copolymer |
VC/OA | 氯乙烯-丙烯酸辛酯共聚物 | vinylchloride-octylacrylate copolymer |
VC/VAC | 氯乙烯-乙酸乙烯酯共聚物 | vinylchloride-vinylacetate copolymer |
VC/VDC | 氯乙烯-偏氯乙烯酯共聚物 | vinylchloride-vinylidene chloride copolymer |
